I just installed os 10.3.9 on my mac, but cannot see the fuze on my desktop when I connect it. I tried changing the USB setting to MSC, but it still does not mount up. Does anyone here use a mac or could offer any suggestions? Thank you kindly
first, check if there’s any problem with the connection. click on the apple icon then choose “about this mac” then click on more info. click on “USB” on the left side of the screen and check if any hardware named “sansa fuze” is connected.
if that’s the case, try changing the label of the player using a windows computer.
if that didn’t work, you can also try formatting the player and resetting it to factory settings.
