Whenever i connect my sansa expressin my windows xp series pc it shows a icon in task bar with no safe eject option and also after 10 seconds it too will dissapear from the task panel… for my device there is no safe eject option at all… pleses give info abt how to do it,…
MTP devices don’t get “safe eject” icons. You can unplug them anytime you want as long as you’re not in the middle of a transfer. MTP is designed that way.
thanks for the info…
Yeah, thanks from me, too. I was also wondering why there was no eject option for this device
