On top level of my sansa clip+ i only found this Dirctories :
AUDIBLE
AUDIOBOOKS
MUSIC
POTCASTS
RECORD
Where is the Directorie for my miniSDCard?
AUDIBLE
AUDIOBOOKS
MUSIC
POTCASTS
RECORD
In MSC mode it shows up as a separate drive, you can just drag your music albums to the root from using windows explorer. I never use MTP or auto mode so can’t speak for those.
What you are seeing on the Clip+ is the “database”, comprised of content from both the internal and external memory locations. The Clip+ (nor any of the Sansa players) read folder/files by default; but instead read (and display) the information in the ID3 tags of the files.
But if you scroll down to the botom of the Music menu and select Folders , you will see them by file name and divided up as on your computer. I believe this is what you’re looking for.
