microSD feel
Thinking of maybe buying a card but got a question first :
When you go down the side with a finger, can you feel the card or do you get a bump similar to the power button on the other side ?
The latter, I would say.
There is a bump but it is very small. Its not enough to really feel as that you have to watch out for it but if you run your fingers over it, you can tell its in. And you dont need finger nails to put it in or take it out.
It’s flush with the case on my Fuze…and no problem at all popping it in or out.
