MicroSD card won't fit
Ok, I just bought this Sansa Express 1Gb at a closeout store and I can’t get my microsd card into the slot. It looks like the slot wasn’t completely widened at the factory, or is this normal? The card is a Sandisk MicroSD M2, is this the wrong card?
If you are pertaining to MicroSD M2  which is the Memory stick Micro II it will not work, MicroSD only is the card for the player. Kindly check this link for more information;
http://sandisk.com/products/mobile-memory-products/sandisk-microsdhc.aspx
Hope this helps. :wink:
