I currently have a E250 and was wondering if you can load video onto the Microsd card on the Fuze. The E250 would not allow this. Thank you.
Yes it works well on the Fuze.
On the e250 - the video that you could load onto it (kills me that it would not let you load it to the microsd) was cut into seperate files of 30 min - it this still the case or is a two hour movie stored as one continious file? thanks again.
Fuze can handle continuous file. its MP4 format.
Thanks for the info - Just purchased the 8gb model at Best buy.
