Micro SD Card, what's best?
I bought several Wyze cams for me and my family which has a microSD card slot. what’s the best Sandisk micro SD card in the market? Assuming the card records 24/7. Is SanDisk Extreme PRO microSDXC reliable and suitable for this kind of cameras?
SanDisk Extreme is what I use in my Eufy security cameras. No problems here. Seems to be working fine !!
The SanDisk Extreme PRO microSDXC card is the top-tier option available and is well-known for its reliability and performance, making it a suitable choice for continuous recording in devices like Wyze cams. These are designed to handle high write speeds and constant use, which is crucial for 24/7 recording.
