Hi
I have currently the 1 gig Express with a 2 gig microsd card
I want to upgrade to a 4 gig sd or 6 gig microsd card. am I able to do so? what kind of card do I need to use in order for this upgrade?
Hi
@amystar wrote:
Hi
The Express is compatible with micro SD cards up to 2 gB and micro SDHC cards up to 4gB.
If you are buying a HC card, I would recommend buying a Sandisk brand card.
Not all brands appear to work flawlessly with the Express.
Check prices at Amazon, the 4gB cards are less than $25.
THank you! I am going to buy a 4 gig card and sell the 2 gig on amazon used. Woohoo…now I can download a few more audiobooks since they tend to take up a lot of room
