Menus on Player Not accessible
Hello
I got a ClipJam player and it worked fine.  Recently, it started jamming.  For example, if I go to the settings screen, it will
jam and I can’t scroll to the other menus like Folders or Music.  Only after pressing the power button, I can scroll back (Settings, Music, Folders) but it won’t go to the submenus and won’t access any files, submenus and won’t play any files.   If I press the bottom button, it won’t scroll through the menu at all and won’t go to the submenus.
It simply won’t play, there is no way to access the files on the player (USB access is still okay, the computer reads the player like any USB drive)
I used the reset method (20 seconds by holding the power button then restarting it again) same problem.  It sometimes scrolls through the menu choices (Music, FM Radio, Folders) but the actual submenus or songs are not accessible.
Is there a solution or workaround to this problem, or is the player not useable?
