I am having problems with my new sansa clip +. I dont know how to change the menu screen. It only shows the headphones and music icon like the link below. How do I change this to get to other menu settings?
https://www.sellyourelectronics.ca/admin/product_resized/SanDisk-Sansa-4GB-Clip-plus.jpg
Peel the protective screen cover off.
Peel the protective screen decal/sticker off. There’s a small tab (usually in the upper right corner) that will help get it started.
How do I change the menu to what I want to listen, such as Motown(Motor City)?
I have something I nvever listened before and I want to go back to what I like to listen to.
If the files are tagged correctly, you could use the Genre listing to find it. Otherwise, use the Artist > Album > Song.
Maybe reading the Clip+ Users Guide could help you too.
This is too hilarious! I had the same “problem”. I have spent two days trying different solutions and finally joined the forum to get help.
Well, I see the menu now, so I can get started.
