Memory Card
will this one work in sansa clip+ 2gb?? http://global.adata-group.com/en/product_show.php?ProductNo=AMC2CL2BK
well then i don’t know why it doesn’t work:/…everytime i start my sansa in this card in it, it stucks at refreshing database…i waited about 15 minutes and it was still in the same position…any idea how to fix that?
with this card in it*
Use a tag editor like mp3Tag and fix the tags on your songs.
how is this gonna help?? and what exactly i should fix on those tags?
If the fuze can’t read the tags on your song files or if the song files are corrupt, it can stay stuck at refreshing the database.
From what you have described so far, it sounds like it’s the card that’s causing the issue.
If the card is new and has this issue from the beginning, then try formatting the card through your computer.  Backup anything that’s on the card, if you haven’t already, before formatting.
yes, the card is new so i’ll try to format it
thanks a lot, formatting helped:)
