Media Converter Causes Conflict with DivX
Running Vista, and i have DivX for windows (codecs, player).
When i install the media cvonverter it prevents Win DVD maker from recognizing AVI files and prevents Vista from displaing AVI file icons.
i burened a dvd with avi files on aug 5, tried to today and it failed, had to do a system restore. reistalled the few programs i installed since then.
sure enough the Media Converter causes the conflict.
anyway to fix?
Paul
Have you tried reinstalling DivX and other such programs *after* installing the Media Convertor?  If SMC is replacing some files that are also used by these programs, running their installers after the fact should fix the problem.
Seems logical enough to me
