Best MBOX to PST Converter tool to migrate AppleMail to Outlook. This MBOX Converter also supports the conversion of corrupt MBOX files.
You can Use the great and admirable tool called MBOX to PST Converter to convert all the MBOX data into single or separate PST with date range filter. The tool is compatible with all MS Outlook editions 2019, 2016, 2013, 2010, 2007, etc. and supportive of all Windows versions such as 10, 8.1,8, 7, XP, etc. You can download the trial version which converts a few items from each folder. you can download this tool from here:-MBOX to Outlook PST Converter
