My new clip worked nicely for about 3 days. Since then it has disconnected itself while copying files, shows low battery even though when connected to computer it shows fully charged, drains to low battery without usage and is currently coneecting & disconecting over and over while I type this. A new clip is already on the way from my retailer, but are any of these problems correctable by me? How good are my chances of getting another clip with problems?
Unless you have my kind of luck, pretty slim.
Your new machine should be just fine! Be sure to update the firmware in it to the newest .20 version.
Bob ![]()
