the only screen i get for main menu options is the equalizer screen. other main menu option s such as MUSIC etc cannot be retrieved. I refreshed the firmware (01.02. 18A) clip+,but no luck. Does anyone have a solution ?
I did not use the player for a while, so I fully charged it, and then I ran into this problem. It was working fine prior to that.
tHE HOME BUTTON does not change the menu from the equalizer screen to other options.
Thank You…Mr. Perplexed.
