hi, my external drive - WD elements worked great with my macbook pro till now. suddenly it can’t read it. it doesn’t even recognize that it connected. i have a lot of important work stuff on it… what can i do?
(also try with another mac and same thing)
Hi michal1,
Maybe you should try contacting WD’s Technical Support about this.
https://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support.
