I’M FRENCH BUT I CAN TRY TO EXPLAIN : Sorry in avance for my “fautes”
I got a WD My Passeport 1 TO and i would like to use it on a Mac under OSX El Capitan an Windows 7 on a PC
I have a message on Mac :“” problème config with RAID please start WD Drive Utilities"
But i don’t have any result and the external hard disc is automaticly éject
Have you tried to partition the drive with disk utility? Also would like to know if you have the WD drive utilities installed on the Mac. In case its installed try to uninstall it to see if this helps.
