I am adding songs to my SanDisk. Songs that I purchased off of itunes are not being copied to my SanDisk, but songs I’ve uploaded to my comp from burnt cds are copying just fine. It shows that they’ve copied to the SanDisk once I check it out when connected to the computer, but once I shut down, they do not appear when I’m on the go. Any ideas?
I believe that the songs you purchased from iTunes are AAC encoded and Clip does not support AAC for now. So if you want to have clip played your songs, you have to convert your songs into mp3 or wma and then put it on the device. As for now, putting your iTunes songs straight to clip won’t work.
