Tried all your suggestions and it still will not sync the drm protected wma files. The message is:
An error occurred while attempting to transfer “The_World-Part01.wma”.
Error Details: Unable to tansfer the selected title because [insert3] returned 0xC00D2711
AFter a couple hours on teh web, this turns out to be a media player 7.1 error message about drm.
I redid the Media Player security upgrade.
Reformated the unit as MTO and MSC.
dont wanna assume, does it play on the computer just fine? if you right-click the file in wmp and select properties, what does it say in the license tab
!(file:///C:/DOCUME%7E1/MaziarLe/LOCALS%7E1/Temp/moz-screenshot-1.jpg) !(file:///C:/DOCUME%7E1/MaziarLe/LOCALS%7E1/Temp/moz-screenshot-2.jpg)This files can be played until 10/22/2007 (and it does play on my laptop)
Collabortive play for this file is not allowed.
This files cannot be burned.
This files can be synchronized 30 more times until 10/22/2007
The media usage rights for this file cannot be backed up
It will say so on the screen of the player when it is connected. Either MSC or MTP. To change it, go through the settings of the player itself. Settings>USB Mode. You want Auto-Detect (MTP) as opposed to MSC.
