I have a Clip+ which died. I tried all the tricks in the book (forum) and nothing worked so far.
It doesn’t work at all or show any sign of life when disconnected, however when connected to the PC it shows up as M200Plus and then installs as UNDEF. The UNDEF is recognized as unformated and cannot be formated by Windows.
I found a threaddiscussing this situation for the e280 which can be fixed with the e200tool. However, I did not find such a tool for the Clip+ and won’t want to brik by Clip+ all together by loading it with the wrong firmware/driver/bootloader.
If I understood this correctly this e200tool is actually created in Linux. I did use Ubuntu a little, but am pretty green on it. I’d appreciate someone helping me along with this.
Any other sugsetions will also be appreciated greatly.
The Clip+ hasn’t been out that long, so it assuredly would still be under warranty. I would take advantage of that. Call Tech Support; they can arrange warranty replacement if they can’t get you back up & running.
