Have an m320 using with Itunes on a mac book. I was able to convert songs to mp3 and then just drag them into the m320 while connected via usb. now I want to delete and add different songs, but when I deleted a bunch of songs on the palyer itself, they don’t show up on the player but the player is still indicating that the memory is full and I can’t add any new songs. I’ve only got 5 songs on it but it says it’s as full as if I had 40 or so. any ideas? thanks.
when you delete a file on a mac, it just transfers it to the trash folder (in case you accidentally deleted a file, you can still recover it). you have to empty the trash first to fully delete the song/s. Ctrl + Click on the trash icon then select empty trash.
