M.2 ssd not detected
M.2 SSD WD-BLACK SN770 IN A SABRENT USB FOR M.2 PCle NVMe NOT DETECTED IN DASHBORD 4.2.2.5
Hi @logcabin
Please refer to the following article for further troubleshooting steps:
Title: Resolve Internal Drive Not Detected by Windows or macOS Guided Assist
Link: Resolve Internal Drive Not Detected by Windows or macOS Guided Assist
WD Dashboard usually can’t detect WD_BLACK drives inside a third-party USB enclosure, because the bridge hides the drive from it. So “not detected in Dashboard” doesn’t mean the SSD is bad.
Check Disk Management (Win + X). If the drive shows there, even as “Unallocated” or “Not initialized”, it’s detected and fine. If it doesn’t show up, try another USB port and cable, reseat the SSD in the enclosure, and test the SSD in another enclosure or a PC’s M.2 slot. Dashboard works best with the SN770 in the PC’s own M.2 slot.
If it has data you need don’t initialize or format it.
