Currently using a sansa clip+.
The min volume just too loud in my iems, so I tune down all the bandwidths equally, which did lower the min volume.
But would that setting be different compared to a default equaliser setting and affect the SQ?
To me, it sound pretty much the same, but just wish to seek confirmation.
TIA.
Replaygain would be a better idea.
TIA.
I have sensitive IEMs, but I only have a problem with the Clip+ radio volume – is your problem limited to the radio, or with everything you play?
(fwiw, this seems to be a good hack for other folks having the same problem with radio volume)
