Low quality album art on fuze.
Hey,
I just added some album art using the drag and drop method onto the fuze.And the album art was not very clear when compared to the album art in the songs that came with the fuze.So my question is how to get high quality album art onto the fuze using any method(drag and drop,wmp or anything.)
@sr_rox wrote:
Hey,
The Fuze does not have a very good resize algorythm.  You tend to get much better results if you resize the art yourself.  I resize everthing to 120x120 (which is the size of the art on the full cover display screen) and it looks much better then when I let the Fuze resize larger art itself.
You mean.Resize the album art to about 120x120 then transfer the album art?If so how to resize the album art?
The art WMP11 adds when you rip with it is usually 200x190-something, but I don’t know if the Fuze has to resize it or not.
You can use any image-editing software; Photoshop, Paint Shop Pro, even the free Photoshop-clone, GIMP.
