Low-cost emergency charger/battery extender--recommended
For those in the market for an emergency charger/battery extender for their Clip, I commend this inexpensive one to you.
charger
It uses 2 AA batteries that fit in the bottom, larger rectangular portion, giving you an idea of the size–just a bit bigger than the 2 batteries.  Uses either rechargeable or non-rechargeable batteries.  Also has an LED at one end to use, nominally, as a small flashlight.  Has a regular-sized USB port, to connect to your Clip with the Clip’s cable.
Available at eBay (a good source) and various electronics sites, including Dealextreme.com, in black or white (try a search on “emergency charger”).  With nice pricing, often in the US $2.50-$5 range including shipping (internationally).
http://www.dealextreme.com/details.dx/sku.26479
Bigger than the small Lenmar battery charger pack, the nice thing with this one is, it can use (and be replaced with) your AA batteries–good for emergencies in a pinch, wherever you are and have spare batteries.
:slight_smile:
