My battery was running low on my Fuze, so I plugged it into my computer to charge it and left it alone for an hour, and by then nothing had charged and the battery was still dying. I went back to plug it in and it just says “Battery too low. System shutdown” whenever I plug it in or turn it on. I’ve tried holding the on slide up for 15-20 seconds like I read as suggestions but that hasn’t helped. Help? Any other ideas on what’s wrong and how to fix it?
Is your cable faulty? or have you tried other usb ports on your computer? you might have a bad usb port on your computer.
DO you need a driver installed for the fuze to reconize it? I know with my old moto phone you needed to install a driver before it would charge on a usb port?
