I was only able to recover docs, folders before April 2016. I lost the PC hard drive the beginning of June 2017. Any ideas, or options would be greatly appreciated.
What’s the name of the backup software you used to back up your files and what operating system are you running on your computer?
Hi Ryan, WD SmartWare, and Windows 10 Home edition.
Sorry I forgot, thank you for your assistance. John
Hi randolph4664,
Does your PC recognize your drive? If yes then you can retrieve all your lost files easily with the help of Stellar Phoenix Windows data recovery software. Just go with the tool, I believe it can help you out.
I thank you Oliver.
