I have submitted a question to support but thought would also ask here. The radio sound cut off suddenly today, but I do have sound from the music player, the sansa updater doesn’t want to recognise my machine or even open up at the moment, I have firmware v02.01.35a so any ideas guys.
Are you sure the radio isn’t paused? Press play/pause while in the radio mode.
And even if the Updater had anything to do with it (which it doesn’tt), you already have the latest firmware release for your original Clip. If you want to re-apply it, it couldn’t hurt, but you’ll have to do it manually. The Updater only updates, hence its name.
And even if the Updater had anything to do with it (which it doesn’t), you already have the latest firmware release for your original Clip. If you want to re-apply it, it couldn’t hurt, but you’ll have to do it manually. The Updater only updates, hence its name.
