Loose object inside of player
High I just bought a 4GB Clip the other day, and after playing around with it a bit, I noticed that I could feel an object (I assume it’s the battery as it feels a bit heavy) moving around inside of the player if I shook it gently.  I’ve tried doing a search on it but I haven’t found anything so I’m wondering if this is a common thing, or if I will need to get a replacement.  Thanks in advance
Message Edited by salem on 06-15-2008 09:42 AM
It is not normal for there to be a loose object inside your Clip. However, I have heard of it happening without affecting the functioning of the player.
If it is working well but for the noise, it is your option to exchange it, or not, during the retail store warranty period.
Okay, thanks for the reply!
