skip back to the previous track (with no wait between 2 and 3)
…the track from 1 starts to play. However, if I follow the same steps, but wait for a second or so between 2 and 3, it remains paused when I step back – which I would say that this is the expected behavior.
Actually, skipping back between tracks only happens only in the first 2-3 seconds. After these seconds you go back to the beggining of the track, and you have to press backward once again. It remains paused on the next track in this case?
I can’t judge this situation as an real issue. Normal behaviour should keep the playback paused no mather u go back/forward in this case.
Thanks, and I just want to be sure I understand – are you also noticing that when you pause it, and click to skip tracks, that sometimes it starts playing when you would expect it to remain paused?
