linux and USB Cruzer Edge
I have linux and I would like to format my cruzer edge but I get the following message when I try to do it: “One or more partitions are busy on /dev/sdb”: How can I fix this problem?
(I use usb-creator-gtk to format my USB key).
Thx.
CruzDg
"One or more partitions are busy on /dev/sdb": How can I fix this problem?
Really?  You need to find which Linux app is accessing the Edge, close it, then run the format.  As for which app it is, I have no idea.
