Hi my sansa language list has a language listed backwards. Can II update my clip on the net somewhere?
Thanks guys
Thanks guys
Not quite sure I follow the issue. If it can help, you can reset the player under its settings, which also will allow you to set the language; or reapply the latest firmware–see the firmware upgrade sticky thread at the top of the forum for the firmware and instructions to do this manually (easy to do).
