Hello. I just bought a WD My Book Essential and installed WD Smartware on my computer. The computer has OS in Spanish. However, I would like to have WD Smartware in English.
Is it possible to change the language, either by going to some option or by uninstalling/reinstalling the software?
Is it at all possible to have the software on a different language than the OS, or does it HAVE to be the same?
First of all, thank you for the interest and help!
I had already seen that post, but the link posted there takes me to an option of downloading an Update of the smartware software I have, there is no mention of a VCD with a language package. Shall I uninstall the software and run the update file as a stand alone installation? Or am I misunderstanding something? Sorry if it sounds stupid.
I searched for an option to change the language after installing the Smartware that came with the drive. Nothing. Then I updated the Smartware to the new version provided in the lnk we’ve discussed. No option to change language. Anything else I can try?
