My Fuse for some odd reason wont turn on now. The bottom port was accidentally plugged in while it was still on and now the player wont turn on.
How do I fix this and why in gods name isn’t there a reset button on the darn thing!!!
There sorta is a reset button. Push the on Switch up and hold it for 15-20 seconds. The fact that you plugged it in while it was on should not have caused an issue. You may have had a preexisting condition…
Make sure you also update your firmware to the latest version. I’ve had constant freezing the first few days I got the Fuze. After the update my Fuze has rarely froze at all.
