when i open wd softwares it shows to “attach a supported device” . my softwares are up to date
Hi fahadfmp,
Which driveare you using and which software did you try to open?
I have the same problem, and started after a recent Windows 10 update. Will WD software be updated to sinc with Windows updates?
