Is there any hope left (recovery) .... 'crashed desktop elements'
Test Option: QUICK TEST
Model Number: WD Ext HDD 1021
Unit Serial Number: [Deleted]
Firmware Number: 2021
Capacity: 2000.40 GB
SMART Status: PASS
Test Result: FAIL
Test Error Code: 06-Quick Test on drive 3 did not complete! Status code = 06 (Failed servo and/or seek test element), Failure Checkpoint = 97 (Unknown Test) SMART self-test did not complete on drive 3!
Test Time: 18:39:26, June 30, 2013
Test Option: EXTENDED TEST
SMART Status: PASS
Test Result: FAIL
Test Error Code: 08-Too many bad sectors detected.
Test Time: 18:39:42, June 30, 2013
Is best to get an experts opinion.
You might want to contact a data recovery company and  in order to make sure if the data on the drive can be restored.
You can also try a data recovery program.
If you are considering professional recovery it’s best to do nothing. You can try recovery software like Recuva   http://www.piriform.com/recuva it’s free. There are several paid programs that let you try recovering a small amount before buying. You can also try running CheckDisk and see if it will fix the errors.
Joe
