I already have SDCZ80-064G-G46 drive and it’s a fixed disk (this drive is listed in Performance tab from Windows 8.1 Task Manager) and require a special preparation to install Windows 8.1 from it, using Easy2Boot.
My question is: SanDisk SDCZ88-128G is also a fixed disk (appear or not in Performance tab from Windows 8/8.1 Task Manager)?
"Recently you requested personal assistance from our on-line support center. Below is a summary of your request and our response.
If this issue is not resolved to your satisfaction, you may reopen it within the next 7 days.
Thank you for allowing us to be of service to you.
Subject
Is SDCZ88-128G a fixed disk or not?
Discussion Thread
Response Via Email (Cornilius L.)
07/30/2014 11:59 AM
Dear Mihai, Thank you for contacting SanDisk Technical Support. My name is Cornilius L. and I am here to assist you.
In mid-2013 SanDisk changed production of its USB Drives configured as fixed disk to meet a perceived certification requirement. SanDisk USB Drives with either removable or fixed disk configuration will work the same when used for data storage on Windows PC and Mac computers. SanDisk is in the process of reverting back to producing USB Drives configured as removable disk.
NOTE: There is no tool available to change SanDisk USB Drives between fixed and removable disk configuration.
Unfortunately, SanDisk Technical support has no way to identify by the packaging or reseller stock whether the drive will show up as fixed or removable disk.
Please provide the below information so that we can verify the authenticity of your drive and register it for warranty purposes:
- Product code and serial number (please provide all the codes written on the product) - Color of the drive - Capacity of the drive - Place of purchase - Date of purchase (MM/DD/YYYY) - Do you see the letter "R" or the word "Refurb/Refurbished" at the back of the product? - How was the product packaged at the time of purchase? - Please also provide your phone number (we use this only for follow up on your case should it be needed and do not use it for other purposes)
Thank you for your kind cooperation and for allowing us to be of service to you!
Using one of our SSD’s? Check out our new interactiveSSD guidefor installation- and usage tips & tricks.
Please refer to your My SanDisk at http://kb-eu.sandisk.com anytime to see all of your incident history and product registration information. You can log in using your email address as your login and the password that you created. Also, you can visit http://kb-eu.sandisk.com our online keyword searchable Knowledgebase, to easily find answers to your Technical Support and Customer Service questions for all of SanDisk's products. Simply enter your search terms and our Knowledgebase will search an extensive database of commonly asked questions as well as our online forums at http://forums.sandisk.com to provide you with the most complete answers possible. Best regards,
Cornilius L. SanDisk Technical Support
Auto-Response
07/29/2014 11:45 AM
Dear Mihai,
Thank you for contacting SanDisk Customer Support. You should receive an email response from a SanDisk Customer Support Representative within 2 business days.
Hi, I've already posted the next question on SanDisk forums: "I already have SDCZ80-064G-G46 drive and it's a fixed disk (this drive is listed in Performance tab from Windows 8.1 Task Manager) and require a special preparation to install Windows 8.1 from it, using Easy2Boot.
My question is: SanDisk SDCZ88-128G is also a fixed disk (appear or not in Performance tab from Windows 8/8.1 Task Manager)?"
Many thanks!
Online registration is available to register your product. For presales inquires, you can chat live with one of our agents. Also, if you see this email in your spam folder, please unspam to receive future emails from SanDisk.
This is a transactional email in response to your request. SanDisk respects your privacy. Our Privacy Policy is available on our website.
[—001:003574:38030—]"
So, my question got an answer and I consider that SDCZ88-128G is a fixed USB drive.
I want to believe you, but a user called Benjamin B. from newegg said that the drive appear in CrystalDiskInfo, and can read from there the drive temperature, which means that the drive is a fixed disk.
