Is sansa compatible with ipod?
is it possible to run the fuze off of an i-pod charger?
Nope. The connectors might look similar but are wired differently…you could fry your Sansa.
The Odds of you Frying your Sansa are HIGH enough that I would bet you would fry it. Sansa Compatible cables are available on Amazon for only a couple of dollars
Doesn’t the Zune use the same cable (lazy Microsoft)
