Is Fuse supported by iTunes library?
Is the Fuse natively supported by iTunes (music library management software on my Mac, not the iTunes Store)? Can iTunes manage music, playlists,  etc on the Fuse?..or is it just another method to manually copy files to the Fuse, recognizing it as an external memory source?
I don’t use Windoze or Mac OS X, so I don’t know about iTunes, but it should show up in Windoze, Mac, and Linux as a flash drive when set to MSC mode. Go to Settings -> System -> USB Mode and set it to MSC mode. Just keep in mind that anything you put on the Fuze in MSC mode won’t show up in MTP mode when connected to a computer supporting MTP (which would be Windoze and, with the libmtp library, Linux).
I don’t think
Itunes will work.
Yes! Yes! Yes! Google “iPod Agent”. It will allow you to use any MSC player with iTunes. It works.
But why bother? Media Monkey rocks and works great wth the Fuze.
Agreed! Down with the iFascist fruits! :smileyvery-happy: (just kidding people)
