IPhone/iPad用サンディスクiXpand フラッシュドライブ
https://www.sandisk.co.jp/home/mobile-device-storage/ixpand
iXpand ™ flash drive iPhone / iPad, easily transfer image videos between Windows / Mac PC. It is possible to free the body capacity of the iPhone / iPad of available instantly to 64GB **.
Automatic image video backup from iXpand ™ connection when the camera roll folder to the drive body.
All of the major video formats corresponding **, can play music files from the drive.
Strong and flexible connector to exert in the iPhone / iPad.
Overview
Easy data transfer between iPhone / iPad and PC
Quickly move the image videos between devices using the Lightning and the USB connector.
The iXpand ™ drive when you connect to the iPhone / iPad, if it is to turn on the pre-auto-configuration, will be image video backup in the camera roll.
More than three times the transfer rate ** of other drive products
From your use of the iPhone / iPad, you can transfer files instantly.
The release of the iPhone / iPad capacity
iXpand ™ 16, 32 or you do not need to worry about free space of 64GB ** capacity.
Play video and music directly from iXpand ™ drive body
That can be downloaded to iXpand Sync app, all of the major video formats support **, can play music files from the drive.
Protect your files over the password
Encrypt the file **
Password-protect the file in your use of the iPhone / iPad, or you can release the same as easily lock them on a personal computer.
specification
  • Interface: Lightning 0 connector (simultaneous two-connector can not be used)
  • Capacity: 16GB, 32GB also 64GB **
  • Portable device compatibility: Lightning connector equipped iPhone / iPad, iOS 7.1 also need more of the software version
  • PC / Mac PC compatibility: Windows Vista®, Windows 7, Windows 8, Mac OS X v10.6 or higher
  • Supported video formats: WMV, .AVI, .MKV, .MP4, .MOV
  • Li-ion battery (3.7V): needs to be charged before use
  • Operating temperature range: 0 ~ 60 ° C
  • Volume: 64.17mm x 36.78mm x 11.80mm
  • 2-year limited guarantee
Application
SanDisk iXpand Sync app when you use this product, our need. Please Danrodo the app from Apple’s offer of App store app.
support
Link
SanDisk iXpand flash drive support information
Various Download
- IXpand user manual
- IXpand Quick Start Guide
- SanDisk SecureAccess software user guide (Mac)
- SanDisk SecureAccess Software User Guide (Windows)
