When I execute TRIM thru SanDisk SSD Dashboard (ver 2.3.2.4), it works. However, the task it creates in the task scheduler fails because of insufficient rights (error 0x800710E0). How can I give the task sufficient rights ?
I use Windows 10 Family 64 bits
Hmmmm…
Perhaps you should use the Administrator User to set the Trim schedule for all User, it could be that the account you are using has not the nessesary rights run it, or the account that it is set to run under has not the nesseary rights, it should be run under the user SYSTEM.
Just my thought on it, not nesseary the the solution.
