installing clip in xp
My old computer, (running Vista), died. My new pc runs xp but dowes’nt recognise the clip. Any suggestions would be gratefully welcomed.  Zac
If you’re in MTP mode I think you need to install a new WMP and maybe SP2 or 3 (MTP is much newer then XP and was added in an update).  Basically, bring up windows update and install everything and then MTP mode should work.
Alternatively, you can switch your player to MSC mode and it’ll mount like a normal USB thumb drive even in stock XP.
