I copied 333 songs to my Sansa Clip, but the display says 337. Does that number include the files on the root of the player(firmware, etc)?
There were no other songs that I could see, when I viewed the directory on my computer. The only other files I saw were on the root of the player. Should I reformat it & transfer my music back?
Anyone know what the original four songs were? I deleted them from my Clip a long time ago.
Miikerman,
No, my player is not in MSC mode since I have not upgraded the firmware. I use a Linux OS, so in order to upgrade the firmware, I would have to borrow my mother’s winxp computer to delete the 4 preloaded songs.
On a different note… is the player supposed to charge EVERY time I plug it into my computer?
Message Edited by Sasafrass452 on 01-07-2008 09:38 AM
Sasafrass452 wrote:
Miikerman,
You can delete the songs by using the Clip’s Settings->Format function.
Also you don’t need the latest firmware in order to put the Clip into MSC mode. Slide the power/hold switch to hold, press down the center button while plugging the Clip into your USB port.
Message Edited by PromisedPlanet on 01-07-2008 09:49 AM
Thanx for the tip… I’d rather not have to transfer all of my songs back onto the player again, just to remove those 4 songs.
Thanx Miikerman, I’ve already removed the 4 songs. I’m well aware that formatting the player removes all of my music, so I certainly won’t do that unless I really want to. Come to think of it, you’re right… the player automatically uses MSC mode when I plug it into my Linux computer. Luckily for me, I can access it as I would any folder on my hard drive, to copy & paste my music to it whenever I want. I would think that’s easier than using windows media player, but maybe that’s just me… Thanx again, you’ve been very helpful ![]()
Message Edited by Sasafrass452 on 01-07-2008 12:06 PM
