I’m having a problem in setting up my Sansa Clip. I’m not fussed about the default folders Albums/Music etc, it looks quite ordered on a computer screen but not in the Clip.
Is it possible to get rid of the defaults and have my own folder structure? All I want is folders something like:
Favourites
Album1
Album2
etc…
I’m quite happy dragging and dropping my own ripped MP3s into various folders.
You can use your own folder structure. But keep in mind that that is only for organization purposes–the Clip uses ID3 tags for cataloging and play, not folder view.
If there are subdirs in there, you will see some errors about those dirs not being valid mp3 files. Just ignore them. The playlist will be right. If you don’t like those errors, you can get rid of them with a -f argument like:
BTW, while confirming this, I found a bug in m3uent and have updated it. It’s at the same place, http://wuest.org/m3uent and ‘m3uent --version’ should say 0.1a.
Miikerman could you kindly post the link to the PlayList manual, thanks.
Not being familiar with MP3 players ID3 tags/PlayLists etc (I’m old ) but OK with computers, I’ve had a look around and a fiddle and it seems, I have created a solution.
Plug your Sansa Clip in/Load Windows Explorer/Navigate to the folder on your Clip that you want to make a playlist of (In my case, My Computer/Sansa Clip/Internal Memory/Favourites) Select the songs you wish to have in the PlayList/Right Click on the selected files and choose Create PlayList from the popup menu/A new file called “New Playlist.pla” is created ready for you to rename or accept. Unplug the Clip from the computer and navigate to the PlayList, Menu/Music/Playlists/Favourites (in my case)/Forward or the Select Button/Press the Select Button again and you are away.
