That they will except, And i don’t plan on using more than 20g of music in the near future (probably only 16) Then wouldn’t it make sense just to get a 4g than a 8g? Since its less expensive and i won’t use all the memory…
(i have a 8 g, but its kinda went kuput)
ah that helps. lets see in 12 gb i have… 2,300 songs… Ill have to do some math and get back to this…lol
Oh and in the original post, i put Except rather than Accept, sorry.
It’s always better to have more memory than you think you’ll need . . .
because one day you will!
Trust me.
You can get an 8gb micro SD on Amazon for less than $20.
If I understand correctly, Emmnemms is contemplating either a 4 or 8GB Fuze , not memory card.
Okay. Well there’s only a $20 or less difference between the 4gb and 8gb Fuzes, depending on what color you want…if that helps
Actually I am more worried about i REALLY want a red one, but they don’t come in the 8gb version
Sandisk! Are you listening!?!?!? I would pay more $ for a red one!?!?!? really, and i would love you forever!!! *hint hint*
