Hello Sansa-Team,
it is possible, that the fuze doesn’t support ID3v2.4.
With ID3v2.3 all works properly! With ID3v2.4 everything is ‘unknown’!
Will this issue fix by the next firmware update?
Regards,
Thorsten
Hello Sansa-Team,
Regards,
Thorsten
ID3v2.3 ISO-88559-1 is the preferred fodder of the Sansas. The other formats just won’t work right. And it’s unlikely that SanDisk will change their firmware so that they do. Get a good tag-editor like MP3TAG (free) and you can convert them 'en masse".
ID3v2.3 ISO-8859-1 is the preferred fodder of the Sansas. The other formats just won’t work right. And it’s unlikely that SanDisk will change their firmware so that they do. Get a good tag-editor like MP3TAG (free) and you can convert them 'en masse".
