On my half filles clip for an art show, how do I remove songs from the clip w/o taking them out of computer storage?
or can I repeat songs on a playlist for this type of app? first q
You can plug the Clip into the computer, then go to My Computer, then open the clip like a flash drive, and you can delete the files from the clip and this wont change what files are on your computer only on your clip. You can also use Windows media, Media Monkey, WinAmp, or Rhapsody, basically any music management software (Not Itunes) to create a playlist and then sync it to your clip.
I have asked this question in this topic I posted yesterday:
is there a way to delete all the playlist from the Clip instead of one song at a time?
apparently, Conversionbox, you provided an answer I needed! thanks! ![]()
PS: why is the ‘email me when someone replies’ is ticked when I have not set it up in my profile? is there a way to turn off the default setting?
