Hello!
I Pluged in my device to the computer and then i formated it from the computer!
BUT!
when i try to get in to the Device DataBase it says to me : Please Plugin a Device to (:G)
But to windows found the device and it work fine before i formated it!!!
and when i tried to turn it up it says
“Not enough space for music Database. Please Free 30MB.”
Help Please
Hi sahar, i think the problem was in incorrect formating
have you tried to format te Clipe again ?
If so, then try to update the firmware
(turn off the Clip, push switch button in hold possition, press but don’t release center button, connect clip to your machine and drug-n-drop fw file into the root of Clip)
I wish i could… but i try to enter the Sansa it says that it need to be Formated00…
