To clarify, the disk you are trying to select is an internal disk or an external disk? If it is internal, please bear in mind that some computer-branded recovey CD’s/DVD’s can only work on the original internal disk drive certified by the manufacturer.
If you are using an external disk, was the image stored under a particular format? Is the external disk drive recognized on other systems?
External WD 1 TB formatted to accept system images.
As I stated earlier the exact WD drive and system images and the steps I outlined to go form 64 bit to 32 bit and back to 64 bit worked a few months ago. Now. no system image is “found” and I can’t choose the drive and find the system image when using the system recovery disk. The same system recovery disk was used a few months ago.
When not using the System Recovery Disk and operating Windows 7 64 bit I can use the WD 1 TB disk for whatever I want.includint reattimg a new system image and file backups.
The question is why can’t the System Recovery Disk find the root system image, or any othe??? since it did so well eralier.
