I can`t copy more than 14k files into my WD Elements disk
Hi. I have a 2 tb Fat32 partishion on my disk and when I copy files into not-root volume I get an error 080070052. I read that fat32 has limit of files in volume 65000 - but I have this error on 13000-14000
In most cases, the problem occurs with files with a name longer than 20 characters. The following are the most likely causes of this error:
The directory or file name already exists on your USB stick. The directory path could not be found on the drive. There is not enough space on the USB stick The directory name is invalid because it contains invalid characters. The USB stick may not be properly formatted.
I`ve created 2 folders and copied files into it and after the size of folders reaches 390 Gb -I got this error. I can copy only 390 Gb in one folder -and this is not limitation of FAT32
